Problem state and state field sync issue
02-23-2024 03:16 AM
In our instance, there is a field label called "Resolved" for problem state field. But it is not available in the state field OOB.
When we sync both "Problem State" and "State" field only Resolved state is having an issue.
I checked the dictionary for the "State" field which is available in task table. I am not sure how we can use that for Problem table.
In state field for the problem table only below states we are getting (OOB) . Not sure how to get the Resolved state here.
Draft
Proposed
Validated
Assigned
RCA in Progress
RCA on Hold
RCA complete
Known Error
Fix Assurance
Pending Closure
Closed
Cancelled
Attached the screenshot.
Please someone suggest the best practice. Thanks.
02-23-2024 03:20 AM
I think, you need to create a new state in Task table as well and mark as active = False and then try to sync.
02-23-2024 03:25 AM
Create new choice on state(task table) field choice list and select table as problem, so it will be added for problem table only.
And then try.
Please mark this comment as Correct Answer/Helpful if it helped you.
Dhanu
