Problem while calling Outbound Rest message via business rule
Hi Friends,
While calling outbound rest message from Async business rule i am getting the below error
REST Msg Outbound - RESTMessageClient : Error constructing REST Message/Method: IPinfo/GetIPInfo: com.glide.generators.InvalidGlideRecordException: Unable to find REST Message Record with Name
I have crosschecked manytimes the correct name of rest message and method , I have gone through lot of articles
related to this error but still couldnt find the exact solution. Can anyone please help me in this ASAP
Note: I am working in scoped application
PFB code if needed
// Add your code here
gs.addErrorMessage('Inside Business rule ASYNC');
try {
var r = new sn_ws.RESTMessageV2('IPinfo', 'GetIPInfo');
gs.addErrorMessage('Testing test message ....'+r);
r.setStringParameterNoEscape('spec', 'geo');
r.setStringParameterNoEscape('ip_add', current.ip_address);
var response = r.execute();
var responseBody = response.getBody();
var httpStatus = response.getStatusCode();
catch(ex) {
var message = ex.message;
})(current, previous);
I would suggest adding gs.info() to debug you code in each step to find out where exactly you code is failing.
I ran into the same issue.  It may have to do with the Scope of the REST Method/Message.  If the REST portion is in global scope, you will need to use the global.<REST Message>
E.g.
var r = new sn_ws.RESTMessageV2('global.myRestMessage', 'DEFAULT GET');
