Problem with Task 6 in CMDB Health Micro-Certification Simulator (Yokohama)
marwel84
After applying the filter conditions for the Certification Filter, I can only see 69 records instead of 123.
I have not deleted anything.
Does anyone have any ideas on how to fix this?
As a result, only 69 CIs are returned.
Would it be a good idea to terminate the instance and start again, or would it be better to create duplicates to reach 123 records?
Tanushree Maiti
Hi @marwel84
Did you execute the scheduled compliance job, so the data is available. If not execute the job as per the mentioned time.
There is a note at the bottom of the task that states:
NOTE: For additional guidance, please review the lesson on CMDB Health Dashboard > CMDB Health Dashboard - Compliance Scorecard in the CMDB Fundamentals course to provide guidance on how to create a compliance audit.
Refer: Micro Certification - CMDB Health
Hi
I know what I have done wrong.
I've put conditions in "Certification filter"
This results diferent matching records.
marwel84
Thanks Tenushree,
I think I tottaly mess it up.
I have created new Certification Filter and Certification Template for scratch.
Then when I have updated Certification Template system created new version of Certyfication Template but did not update Audit.
I will try to revert all changes and start again.
