ā03-07-2022 03:25 AM
Hello All,
Hope all are doing good !!
ACLs (Security rules) should not have GlideRecord/GlideAggregate in script
We have a custom ACL written as shown below using GlideRecord. How can i replace this code so that it does not use GlideRecord query. or is it even possible in this case?.
var loggedInUser = gs.getUserID();
var supplier = current.getDisplayValue('u_affected_supplier');
var grm = new GlideRecord('sys_user_grmember');
grm.addQuery('user', loggedInUser);
grm.addQuery('group.parent','ba466ab6db802f40978724b3ca9619fa');
grm.query();
while (grm.next()){
var groupSource = grm.group.source;
if (groupSource == supplier || current.u_affected_supplier.nil()){
answer = true;
else{
answer = false;
Kumar.
ā03-07-2022 03:51 AM
update as this
answer = isChangeUser();
//give read access to this Vul Item if the user is associated with a Change associated with it
function isChangeUser() {
var flag = false;
var usr = gs.getUserID();
var m2m = new GlideRecord('sn_vul_m2m_item_task');
m2m.addQuery('vulnerable_item', current.sys_id);
m2m.query();
while (m2m.next()) {
var chg = m2m.task.getRefRecord();
if (chg.requested_by == usr || chg.u_change_manager == usr || chg.assigned_to == usr || gs.getUser().isMemberOf(chg.u_coordinator_group) || gs.getUser().isMemberOf(chg.assignment_group))
flag = true;
break;
return flag;
regards
ā03-07-2022 03:28 AM
I don't think without GlideRecord it's possible
ā03-07-2022 03:30 AM
Hello Ankur,
Thanks for your Response!!!
ā03-07-2022 03:35 AM
Hello Ankur,
Can the below code bereplaced or is it possible in any other way?
m2m.query();
return true;
update as this
var flag = false;
m2m.query();
flag = true;
break;
return flag;
regards
