07-26-2022 04:07 AM
Hello
I have one field on catalog item and I make it read-only but it is not greyed out. I don't know why.
That field is not editable.
Guys, please suggest something.
Field : Job title.
08-14-2022 01:39 AM
Hi ,
Did you get the resolution on this ? I also face the same issue ,better to create the HI ticket for this. In my case even if I create new variable with single line text and make it read only from dictionary level or using UI policy then it makes that field read only but not greyed out. But if I change the field type to reference then it was working fine. May be it is instance issue because of upgrade.
Gunjan Kiratkar
07-26-2022 04:29 AM
How are you making this field read only
07-26-2022 04:31 AM
using ui policy, catalog client script
07-26-2022 04:38 AM
Both of them?
I hope you understand client script runs first and then UI policy, so whichever condition you have in UI policy will override client script logic.
Its suggested to keep them in one place, so you can better handle the order of the execution.
There must be some conflict there which is causing this.
07-26-2022 04:31 AM
share the script or UI policy which is making it readonly?
07-26-2022 04:43 AM
