ReadOnly the AssignTo field if not in group (upon selecting group)
Jeff316
I've already created an ACL that makes the Assigned To field writable only if the logged on user is a member of the current assignment group.
That's all good, except if I'm on the incident form and I am a member of the assignment group and I change the assignment group to one that I am not a member, the assigned to field will not change to readonly based on the ACL until I save the form.
I need a client script that can sense that I've selected a new assignment group in the GUI and at that very second the assigned to field needs to become read only because I'm no longer a member of the soon to be current assignment group.
What is the client script I should use for this or is there another way?
Thanks for the help.
oharel
Hi Jeffrey,
I like using onChange client scripts that call GlideAjax:
Client script (onChange of assignment group)
var thisUser = g_user.userID;
var ga = new GlideAjax('findAG'); //the script include
ga.addParam('sysparm_name','getUser'); //the function
ga.addParam('sysparm_user', thisUser);
ga.addParam('sysparm_grp', newValue); //the new AG
ga.getXML(getTheUser);
function getTheUser(response) {
var myAnswer = response.responseXML.documentElement.getAttribute("answer");
if(myAnswer == 'no') {
g_form.setReadOnly('assigned_to', true);
} else if(myAnswer == 'yes') {
g_form.setReadOnly('assigned_to', false);
Script include:
Client Callable: yes
Script:
var findAG = Class.create();
findAG.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getUser : function() {
var thisUser = this.getParameter('sysparm_user');
var thisGrp = this.getParameter('sysparm_grp');
var user = new GlideRecord('sys_user_grmember');
user.addQuery('group', thisGrp);
user.addQuery('user', thisUser);
user.query();
if(user.next()) {
return 'yes';
return 'no';
      type: 'findAG'
harel
Thanks for the update. In that case, I would recommend you to create a OnChange client script + GlideAjax. More info on GlideAjax
How to Write Smart GlideAjax Quickly
You can copy the script from other link and adjust it accordingly.
oharel
Hi Jeffrey,
Script include:
Script:
user.query();
if(user.next()) {
return 'yes';
return 'no';
      type: 'findAG'
harel
Harel,
That script is very nice.
I appreciate you sharing it with me.
It's tough being the new guy.
I feel like I'm cheating when I have to ask someone for help.
The script is working perfectly.
I hope to return the favor some day.
Jeff Mangan
