Record producer - how to highlight the question text
pfriis
Mega Contributor
I would like to highlight the question text in the variables i a record producer. Anyone, that have the recipe to how I can change the text to bold.
Variable in a record producer:
The form in action..
11 REPLIES 11
It is working fine for me. Record Producer -- > variable --> Question
I get the same result as you at the SN backend, so from hear everything is fine! But unfortunately I do not get the same result at the Service Portal. Maybe it is necessary to make a change to the SP-settings. Do you have an idea..?
Hi Deep K, have you publiced the record producer though a catalog item on the service portal? The change is alright on the backend when I click on the try it buttom in the record producer. But the HTML-code will not work on the service portal..
Sorry, Don't have idea for Portal.
I would like to do this as well.  We have long forms in the portal that need some sort of divider between sections.  Any idea?
