‎09-30-2020 02:53 AM
Hiya Guys
I logged this issue to HI by they advise they couldn't help and to reach out to the community.
I have created three new record producers (using the "copy" functionality of the OOTB record producers for; propose a standard change template, modify a standard change template and retire a standard change template)
I have linked my copies to different pages within the Service Catalogue and I'm getting this error;This is one of the new record producers that i have created (the example below is to propose a template):
When i click on "Try it" from the record producer view, i can see the form.. it works fine. It just seems to be the portal that's the issue? Any ideas?
Thank you in advance!!
Change Management
Service Catalog
‎09-30-2020 03:22 AM
Can you check the Hide on Service Portal checkbox.
Pooja M
‎05-18-2023 06:00 PM
@Pooja Mallikarj , I have seeing the same issue as well , The record producer I created does not appear in portal search engine . Did you find a solution ?
