10-05-2015 01:29 PM
I have a Record Producer for requesting the creation of a new employee (on boarding). The Record Producer fires a workflow to create tasks associated with the process. Information from the Record Producer is passed to the tasks via script (
10-05-2015 07:35 PM
I Stuart,
I am not able to see the script section you have provided. Not sure if it is missing in the question itself or I am not able to see it.
Since your sys_id is being passed to the workflow, you can get the display name of the user record by using following code.
var gr = new GlideRecord('sys_user'); // initialize the object of the record.
gr.get('sys_id'); // pass on the sys_id of the manager here
gs.log(gr.getDisplayValue()); // log a manager record display name for debug / test purpose
var display = gr.getDisplayValue(); // store the display name in a variable
I hope this helps you to proceed with your workflow script.
10-06-2015 06:05 AM
Welcome.
12-01-2021 02:22 AM
Hello everyone,
I am experiencing the same issues.
Where do you apply the script above?is it a client script? or script inside the flow?
Thanks!
02-06-2025 10:40 PM
You can use OnLoad Client Script
