09-15-2017 10:45 AM
Greetings Everyone!
I have a catalog item and have a classification Field( Variable) which is reference to custom table ( Classification). I have created a UI page in my Catalog Item with Group Roles and User ID.
Now, the Group Role is reference to Custom Table ( Group) which has Group Roles tagged to Classification above ( Only two Classification, A & B).
Now, My requirement is If I choose A in my Classification Field,Only the roles tagged to A should be listed in my Group Role Field and If Chosen B, the roles that are tagged to B should be listed in my Group Role reference field.
I have tried different option but no luck. Please let me know if there is something way we can achieve my requirement.
My HTML Code:
<TD><g:ui_reference name="group_role" query="u_classification=u_pgm_classification.value" id="Group_Role" table="u_pgm_group_role" completer="AJAXTableCompleter" columns="u_group_role" /></TD>
<TD><g:ui_reference name="ln_user" query="active=true^u_employee_type=SAPHR" id="ln_user" table="sys_user" completer="AJAXTableCompleter" columns="user_name" /></TD>
Corresponding Client Script:
var root = document.getElementById(r);
var allRows = root.getElementsByTagName('tr');
var cRow = allRows[1].cloneNode(true);
var j = 0;
for (j = 0; j < cRow.cells.length; j++) {
if(j>0 && j!=4){
document.getElementById('fn_user').value = '';
document.getElementById('sys_display.fn_user').value = '';
document.getElementById('ln_user').value = '';
document.getElementById('ln_user').name = '';
document.getElementById('sys_display.ln_user').value = '';
root.appendChild(cRow);
function deleteRow(r) {
try {
var table = document.getElementById(r);
var rowCount = table.rows.length;
for(var i=0; i<rowCount; i++) {
var row = table.rows[i];
var chkbox = row.cells[0].childNodes[0];
if(rowCount>2){
if(null != chkbox && true == chkbox.checked) {
table.deleteRow(i);
rowCount--;
i--;
catch(e) {
alert(e);
09-25-2017 08:20 AM
Hi Ankur,
Apologies for the delay in response. I tried in my personal instance and its not working as expected. Would you be able to check mine if I share my creds?
Pls confirm. I will mail the details..
Shan
06-18-2024 03:24 AM
Hi everyone,
I know this is quite an old post, but I was facing a similar issue recently and I was able to solve this problem with a new approach. I wanted to share my solution in case anyone else encounters the same challenge.
Solution:
I used an approach that takes the value from the first reference field, sets it as a preference, and reloads the modal with this preference. The Jelly script then evaluates the preference (choice sys_id) and populates the GlideRecord for the choice record. This allows us to automatically populate the user's previous selection in the reference field using the sys_id and the display value, while also generating the dynamic reference qualifier for the second reference field.
HTML:
<g:evaluate var="jvar_choiceGR" object="true">
var choiceGR = new GlideRecord('sys_choice');
choiceGR.get(RP.getWindowProperties().get('choiceID'))
choiceGR;
</g:evaluate>
<g:ui_form>
<!-- Category Reference Field -->
<div class="form-group" style="display: flex; gap: 2rem; align-items: center;">
<label style="flex-shrink: 0" for="sys_display.category">
${gs.getMessage("Select Category")}
</label>
<g:ui_reference style="width: 100%" name="category" id="category"
table="sys_choice" query="name=incident^element=category^inactive=false"
value="${jvar_choiceGR.getUniqueValue()}" displayValue="${jvar_choiceGR.getDisplayValue()}"
onchange="updateSubcategory(this.value)"/>
</div>
<!-- Subcategory Reference Field -->
<label style="flex-shrink: 0" for="sys_display.subcategory">
${gs.getMessage("Select Subcategory")}
</label>
<g:ui_reference style="width: 100%" name="subcategory" id="subcategory"
table="sys_choice" query="name=incident^element=subcategory^inactive=false^dependent_value=${jvar_choiceGR.getValue('value')}"
value="" displayValue=""
onchange=""/>
</div>
<!-- Footer action buttons -->
<div align="right" class="modal-footer">
<g:dialog_buttons_ok_cancel ok="return onSubmit()" ok_style_class="btn btn-primary"
cancel="window.GlideModalForm.prototype.locate(this).destroy(); return false"
ok_text="${gs.getMessage('Update')}" cancel_text="${gs.getMessage('Cancel')}" />
</div>
</g:ui_form>
</j:jelly>Client Script:
function updateSubcategory(choiceID) {
var gm = GlideModal.prototype.get("community_demo"); //This is the name of the UI page
gm.setPreferenceAndReload(
{ "choiceID": choiceID }
