Reference field is not showing display value
Nagasri
Reference field is not showing display value but the value is set. We have checked the display value of the table of the referenced table. Display value is set true for only one field.
11 REPLIES 11
Did you find the solution for your issue ?
I have a similar situtaion :
 I also have a custom table and a reference field added
But when click to populate the reference field , it comes back blank even though I can see the data in the lookup list.
If you have found the answer, could you please post the solution?
Many Thanks in advance.
sunil_m_l10
Hi @Nagasri
Make the Display checkbox true for Name field onto the table which is referenced by City Field.
Sunil
