08-25-2023 04:01 AM
Hi experts,
We have a requirement to apply reference qualifier for a reference field based on for form view. We have 2 views for location table say A & B. The reference qualifier specified on the Dictionary entry should be applicable only for view A and not on B.
I have already checked the exact similar question in community but didn't find the solution. Solved: Re: Reference Qualifier based on Form View - ServiceNow Community
How can we achieve this.
TIA.
08-25-2023 05:03 AM
@Community Alums - Please update the encoded string and form view then try. Please make sure this change should not have any impact to other table that has reference to the locations table which is one of the foundation data.
javascript: gs.action.getGlideURI().getMap().get('sysparm_form_view') == 'view A' ? 'encoded query string to apply for view A' : 'encoded query string to apply for view B'
08-25-2023 07:59 PM
Hi @Vasantharajan N ,
I have added the code in advance reference qualifier to show all employees including active=false for opened_for field but auto complete suggestion are displaying after adding this code and the other field 'subject person' has simple reference qualifier with active=false and displays autocompleter suggestions.
Below is the screenshot with inactive user tried searching in both fields.
Openedfor attributes also have refautocomplete fields.
How can I enable this autocompleter.
TIA.
06-23-2026 02:14 PM
I need something like this, but this solution is not working for me. In my case, this is for a list vs a reference so not sure if that complicates things. Tried switching sysparm_form_view to sysparm_view, but no dice. Anyone else get this to work?
06-24-2026 06:34 AM
I figured out a different solution, ditching the URL parameters altogether. Instead I used javascript:gs.getPreference('<tableName>.view')=="<viewName>"?"<query1>":"<query2>". If more options are needed, probably best to write a script include for it. Hope this helps someone else!
