Reference qualifier is not working as expected.
Kumar147
I have two reference fields on a form. one is platform and second one is CMDB. CMDB is on task table. platform field is getting data from data management table and CMDB is getting data from cmdb_ci table. data management table having a list field which is reference to CMDB. when CMDB field is filled i need the reference qualifier to show only records related to that CMDB field.
script include:
var app = current.cmdb_ci;
var gr = new GlideRecord(‘table name);
gr.addQuery(‘u_applications’, app);
var result = [];
while(gr.next()){
result.push(gr.sys_id);
return result;
advanced ref qualifier : javascript: new script include name().function();
please help in this.
Thanks in advance
Hi @Kumar147 ,
You have not followed my instruction.
Not sure why you are writing script include.
Just add below code in your reference qualifier of plateform filed. nothing else is required.
javascript:'u_cmdb_listLIKE'+current.cmdb_ci
replace "u_cmdb_list" with your field name which present on your data management table.
9 REPLIES 9
Hi @Kumar147 ,
try below code
“javascript: ‘u_app_platform=‘+current.cmdb_ci”
2nd field name are you having cmdb_ci or something else? Put correct field name.
do share screenshots if does not work.
both field and reference qualifier .
Hello @Runjay Patel
2nd field name is cmdb_ci only. But its on task table.
Hi @Kumar147 ,
Then it should work, i had tested this. You can share the screenshots for your configuration.
Hello @Runjay Patel
I Have tried that but no luck. I am getting app value but still field is showing all values. please find the screenshots of script include and advanced reference qualifier.
Hi @Kumar147 ,
