Reference Qualifier to filter locations based on User Location
mattfollowell
I have a variable on a catalogue item that references the locations table. I want that variable to only list locations whose parent = the signed in user's location. EXCEPT if the signed in User's location = MG. If the signed in user's location is MG then I want the variable to list all locations on the table.
function advloc() {
var locPar;
var userLoc='';
var gr=new GlideRecord('sys_user');
gr.addQuery('sys_id',gs.getUserID());
    while(gr.next()){
        userLoc=gr.location;
    if(userLoc.includes("MG")){
        locPar = "";
    else {
        locPar = "parent = userLoc";
return locPar
I think it is not working because it returns the name of the location and not the Sys_Id, but I'm not 100%.
You're on the right track. That script belongs in a script include that is client callable:
And in your reference qualifier you would just do:
new getLocation().locations();
39 REPLIES 39
Mark asked that I added. "gs.info('DEBUG: ' + gr.location.getDisplayValue() + ' / ' + locaPar);"
For Debugging.
And unfortunately not. 😕
Even when I remove the debug text it still does not work.
Ah oke, so the location is "AL"?
Only somehow locPar is not written to the logs... (or I made a typo when asking to add logging... because I wrote locaPar... an a to many! my mistake)
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Yes, the user I am testing with has the Location of AL. I'm trying to see if the "else" applies.
Lol, don't worry I caught your typo and changed it when I added it to the script.
Ah oke. You could add debugging to both the if and the else, to see which is reached.
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
It seems like it is working. AL doesn't have MG in it so the location should be "".
