reference variable
12-06-2024 01:48 AM
I have a reference variable 'incident number' which refers to incident table. When we click on the search glass of that reference field it will open the list of the incidents. The requirement is only incident number, assignment group and short description columns must be shown on that list.
Can anyone please help me out.
12-06-2024 03:08 AM
Hi @Bhavya11
By default, it is showing the columns incident number, assigned to, assignment group and short description when variable attribute is empty. I need to remove assigned to as per the requirement.
Tried this below but did not work. Still it is showing the columns incident number, assigned to, assignment group and short description.
ref_auto_completer=AJAXTableCompleter,ref_ac_columns=number;short_description;assignment_group,ref_ac_columns_search=true
12-06-2024 03:30 AM
Hello @abhisek
- This is how the Type specification section looks like:
- Add this in variable attributes section and save:
ref_ac_columns=number;short_description;assignment_group,ref_ac_columns_search=true,ref_auto_completer=AJAXTableCompleterResult in portal:
This works in my PDI. Hope this helps!
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps others find the solution more easily and supports the community!"
Thank You
Juhi Poddar
Juhi Poddar
12-06-2024 04:24 AM
Hi @Juhi Poddar
Thanks for your reply.
Yes, it is working from portal but not from maintain item. Is it applicable for a variable which refers to a custom table as well ?
12-06-2024 08:56 AM
Hello @abhisek
You are correct! This will work in portal only. If you want to change the layout in maintain items then you directly configure the list layout.
Hope this helps!
Thank You
Juhi Poddar
Juhi Poddar
