10-28-2020 01:39 AM
I have a requirement where i need to give specified time to user to review the form. when user clicks on alert button then my ui page should refresh. So that i can get all default values that was there on that ui page and my timer can restart .
I am not getting any code to refresh ui page so that my ui page timer restarts with default values.
Pls help.
Nikita
Request Management
Service Catalog
11-02-2020 12:15 AM
Hi Nikita,
I have created a similar case and I could achieve it. Here is what I have done.
UI action
function openPage(){
var dialog = new GlideDialogWindow('Test UI');
dialog.setTitle(getMessage('Testing 123'));
dialog.setPreference('label', 'Can you please choose an option?'); // This is the input for UI page, which would be default
dialog.render();
UI page
HTML
<g:ui_form>
<!-- Get values from dialog preferences passed in -->
<g2:evaluate var="jvar_label" expression="RP.getWindowProperties().get('label')" />
<g2:evaluate var="jvar_optionName" jelly="true" object="true" >
var options =RP.getWindowProperties().get('optionName');
options = options.split(",");
var choiceArray = [];
//<![CDATA[
for(var i = 0; i<options.length; i++){
choiceArray.push(options[i]);
choiceArray;
</g2:evaluate>
<input id="label_id" type="HIDDEN" value="$[jvar_label]"/>
<!-- Set up form fields and labels -->
<table width="100%">
<tr>
<td>
<g:ui_choice_input_field name="TestChoice" id="chooseOption" label="$[jvar_label]" mandatory="true">
<option value="">${gs.getMessage('-- None --')}</option>
<option value="other">Other</option>
</g:ui_choice_input_field>
</td>
</tr>
<tr>
<td colspan="2">
</td>
</tr>
<tr id="dialog_buttons">
<td colspan="2" align="right">
<g:dialog_button_ok ok="return getChoices()" ok_type="button" />
</td>
</tr>
</table>
</g:ui_form>
<button onclick="reincarnate()">Cancel</button>
</j:jelly>
Client Script
function reincarnate(){
var labelValue = document.getElementById("label_id").value;
GlideDialogWindow.get().destroy();
setTimeout(function(){ openPage(labelValue);}, 1000);
function openPage(value){
dialog.setPreference('label', value);
dialog.render();
In above example, I could destroy the GlideModal and recreate it.
In your case, You could create hidden input fields and store the values of parameters inside those hidden inputs.
Below are the inputs I see you are receiving in UI page
<j:set var="jvar_email" value="${JS:RP.getWindowProperties().get('email_ids')}" />
<j:set var="jvar_ccemail" value="${JS:RP.getWindowProperties().get('ccemail_ids')}" />
<j:set var="jvar_bccemail" value="${JS:RP.getWindowProperties().get('bccemail_ids')}" />
<j:set var="jvar_blacklist" value="${JS:RP.getWindowProperties().get('bclist_ids')}" />
<j:set var="jvar_sys_id" value="${JS:RP.getWindowProperties().get('sys_id')}" />
<j:set var="jvar_subject" value="${JS:RP.getWindowProperties().get('subject')}" />
Further on cancel, you can reopen the UI page by passing setpreferences from hidden fields.
Note : You need to use setTimeout and get value of hidden fields into variable before detroying the GlideModal.
10-28-2020 03:44 AM
Do you want to reload the form?
you cannot refresh the UI page without reloading it
If user clicks Cancel the UI page will be destroyed.
They will have to again click on that UI action to invoke the UI page
10-28-2020 04:57 AM
ok. Can you pls tell me what code to write to reload the form.
10-28-2020 05:08 AM
so you want to reload the form when they click cancel
update as below
if (diff < calctym) {
var c = confirm('The standard time for this page is '+calctym + 'seconds & only '+tymlimit+'seconds is elapsed now. Please Click Cancel to review this page else click OK.');
if (c) {
location.reload();
// alert('You clicked Cancel button')
return false;
10-28-2020 05:24 AM
hi Ankur,
Reloading/Refreshing of UI page isn't possible? I want to see the default ui page when user clicks on Cancel button.
location.reload(); is reloading RITM form and removing ui page too.
Nikita
10-28-2020 06:15 AM
Hi Nikita,
Then in that case as I mentioned earlier you need to call the UI page again
But this is not tested
// your new Code to GlideDialogWindow
var dialog = new GlideDialogWindow("ui page name"); //name of UI page here
dialog.setTitle("Show value"); //Set the dialog title
dialog.setPreference("sysparm_sysID", ''); //Pass your parameter gere
dialog.render(); //Open the dialog
//GlideDialogWindow.get().destroy();
