Remove Choose Options from Order Guide
KARAN24
Hi Team,
We have a order guide where we need to remove the choose options ,is there any way do it.
Karan
Barkha Achhada
Kilo Expert
I don't think that's possible for any particular order guide to remove the "Choose options" as it shows the catalog items variables and that's the main part of order guide to have variables values from user.
But you can remove last tab of checkout by clicking on "Two step" on order guide if you like.
Barkha A
Martin Ivanov
Were you able to achieve what you wanted? Mark Correct and Helpftul, if yes.
Please mark Correct and click the Thumb up if my answer helps you resolve your issue. Thanks!
Martin Ivanov
ServiceNow MVP 2023, 2024
