remove duplicates from an array and get unique values
Vijay27
var text=[];
text = new GlideRecord("sn_hr_core_hr_tasks_per_case_type");
text.addEncodedQuery("u_task_visibilityLIKE" + topicCat + "^ORu_task_visibilityISEMPTY");
text.addQuery("u_generation_type", "manual");
text.addNullQuery("u_auto_group_pref","test");
text.query();
while(text.next()) {
taskArray.push(text.getUniqueValue());
19 REPLIES 19
Santosh_Ksagar
Hi Vijay,
Please try using this syntax:-
It's giving the correct result for me.
 var  names = ['D', 'B', 'A', 'A', 'C', 'A'];
 var  unique = [...new Set(names)];
 console.log(unique);
 // Output---> ["D", "B", "A", "C"]
Please mark my answer as correct if it has helped you.
Santosh Kshirsagar
www.dxsherpa.com
Yogish Naik1
https://www.geeksforgeeks.org/sets-in-javascript/amp/
Yogish Naik1
var text=[]; text = new GlideRecord("sn_hr_core_hr_tasks_per_case_type"); text.addEncodedQuery("u_task_visibilityLIKE" + topicCat + "^ORu_task_visibilityISEMPTY"); text.addQuery("u_generation_type", "manual"); text.addNullQuery("u_auto_group_pref","test"); text.query(); while(text.next()) { taskArray.push(text.getUniqueValue()); } var result = new Set(taskArray) ; will gives unique value
SaiRaviKiran Ak
Use the built in ArrayUtil Script Include :
var noDuplicates = new ArrayUtil().unique(arr);
Can you mark the answer as Correct if it helps you?
