Remove OOTB messages on state transition on a problem
KimAlsgaard
Hi all,
I have a requirement to show a friendly user message, if a user is not permitted to move a problem from state resolved to closed. There is a quality assurance check, so only those with the role "problem_manager" must be able to move from resolved to closed.
On the image below I have added a message in a user friendly language. Is it possible to remove the other two messages, so only mine is shown to the user?
I have tried to add a business rule to run before update with this condition: previous.state == 106 && current.state == 107 && !gs.hasRole('problem_manager') but it doesn't work (nevermind the "technical lead", that's for non-major problems). It still show the OOTB messages.
    var user = gs.getUser();
    var isProblemManager = user.hasRole('problem_manager');
    var isTechLead = ((user.getRecord().getValue('title') || '').toLowerCase() == 'technical lead');
    var stateWasResolved = (previous.state == 6); // Resolved
    var stateIsClosed = (current.state == 7);     // Closed
    if (stateWasResolved && stateIsClosed) {
        if (current.major_problem == true || current.major_problem == 'true' || current.major_problem == 1) {
            if (!isProblemManager) {
                gs.addErrorMessage('Only Problem Managers can close a Major Problem.');
                current.setAbortAction(true);  // blocks transition
            if (!(isTechLead || isProblemManager)) {
                gs.addErrorMessage('Only Technical Leads or Problem Managers can close this Problem.');
})(current, previous);
Ankur Bawiskar
@KimAlsgaard
You cannot suppress those OOTB messages as they come from platform level.
With your new business rule as well it won't work.
Ankur Bawiskar
@KimAlsgaard
Thanks, so at least I won't have to pull off any more grey hairs over this 🙂
