Report on time between change 'Review' state and 'Planned Start'
ebaileyybs
We are looking to create a report for Change Management which will show the time between a change moving to 'Review' state and the 'Planned Start' date of the change record.
We would like the time to be calculated for every change, so the information can then be exported and we can work out an average. However if there is a way to obtain the time between Review and Planned Start for each record and an average then that would be great.
Please let me know if further information is required.
Thanks in anticipation,
Emma
Hi Emma,
Lets keep things simple and get this done
Business rule script
var planned_start_date = gs.now()
var daysDuration = gs.dateDiff(current.start_date,gs.now());
current.u_lead_time =daysDuration;
/*I have tried this on demo and its works just fine(provided you planned start date has a value, you can add checks).*/
And Lead Time field is 'duration'
You can see the same if you log on to
https://demochannel.service-now.com
Create any change request
15 REPLIES 15
That would be great if you could help with the script please?
Hi Anurag,
Thank you for your reply.
Would a script be required to achieve this type of metric?
I have very little knowledge when it comes to scripting so was looking for some advise on how this could be achieved?
Kind regards,
Emma
just confirming the requirement here. You want to calculate the difference between the planned start date and the actual time when the ticket moved to review.
Write a Business Rule
When : Before
Table: change Request
Condition: current.state.changesTo('Review')     //here you will have to provide the numerical value of the state
Script
var getUserDateFormat = gs.getDateFormat();
var dateFormatHelper = new DateFormatHelper();
var currentDate = dateFormatHelper.getDateInUserFormat(gs.now() , getUserDateFormat);     //this is the date when ticket moved to review
var planned_start_date = dateFormatHelper.getDateInUserFormat(current.start_date , getUserDateFormat);   //planned start date in the specific format
var daysDuration = gs.dateDiff(planned_start_date ,currentDate);
current.<your field where you want to save duration > =daysDuration ;
/* Duration gets calculated in format - days hours mins seconds(25 10:55:52),if you have to extract the day part from it.
dateDifference = daysDuration.split(' ');
This should work
Thank you, I have created the business rule and added a new field to the change_request table named u_lead_time. The field is a string field but I have also tried with Integer and this doesn't work either.
Unfortunately, the 'lead time' field is not populating with the output of the script. Please could you advise if you see any errors or what could be causing this problem?
Please see below condition and script:
Condition: current.state.changesTo('-5')
Script:
var planned_start_date = dateFormatHelper.getDateInUserFormat(current.start_date, getUserDateFormat);   //planned start date in the specific format
var daysDuration = gs.dateDiff(planned_start_date,currentDate);
current.u_lead_time =daysDuration ;
Make the Field type duration (glide_duration)
If that dosent work properly then
modify this line of the code
current.u_lead_time =daysDuration.toString() ;
