Request state is not updating via update record in flow designer
04-09-2024 09:18 PM
Hi Community,
Trying to update request state via update record in flow designer but it is not updating request.
Other fields are setting but not request state when it is approved.
When rejected working fine but on approved facing this issue.
04-09-2024 11:59 PM
@shweta14 As per the flow, current you have declared the stages as below?
First set in loop : [Which sets the request state]
Waiting for Approval
Above Line no : 7 (Not sure of the stage - share it if possible)
Request Completed
Second set in loop : [Which doesn't set the request state]
Approval Rejected
Approval Approved
Request Completed
04-10-2024 12:35 AM
If I add request state in update record it will update the REQ request state but then approval is showing requested
04-09-2024 09:53 PM
Hi @shweta14
Are you closing the RITM before making the REQ as Closed Complete ? If not, please make use of one more Update Record action before your action to mark the RITM as Closed Complete and then retry.
Thanks and Regards
Amit Verma
04-09-2024 09:59 PM
yes i'm closing RITM before REQ as close complete
but after that using update record for REQ it is not updating REQ request state
04-09-2024 10:08 PM - edited 04-09-2024 10:10 PM
If you are closing the RITM before REQ, you already have an existing OOB BR on RITM table.
Doing this step in the flow, should make the BR cascade the value to Parent (REQ) record.
Please mark this as helpful and accept it as a solution if this resolves your query.
Sujatha V.M.
