REST API and script include
tsoct
The script included below is returning an undefined error. How can I pass the bearer token to other function within the script include?
Imagine i will have more function within this script include, and not limited to only one getORG
var GetCostCenterDetails = Class.create();
GetCostCenterDetails.prototype = {
    initialize: function() {},
    _getToken: function() {
        try {
            var rest = new sn_ws.RESTMessageV2('CPNYCostCenter', 'Get Token');
            var response = rest.execute();
            var responseBody = response.getBody();
            var httpStatus = response.getStatusCode();
            if (httpStatus.toString().startsWith("2")) {
                var parsedData = JSON.parse(responseBody);
                var token = parsedData.access_token;
				return token;
                gs.error('No token generated');
        } catch (ex) {
            gs.error("\nException occured: " + ex);
    getORG: function() {
        var result = {};
        try {
			var token = this._getToken();
            var rest1 = new sn_ws.RESTMessageV2('CPNYCostCenter', "Get ORG");
            rest1.setRequestHeader('Authorization', 'Bearer ' + token);
            var response1 = rest1.execute();
            var responseBody1 = response1.getBody();
            var httpStatus1 = response1.getStatusCode();
            if (httpStatus1.toString().startsWith("2")) {
                var parsedData1 = JSON.parse(responseBody1);
                if (parsedData1.value) {
                    fields = [];
                    var keys = Object.keys(parsedData1.value[0]);
                    for (var i = 0; i < keys.length; i++) {
                        var resultObject = {};
                        resultObject.name = keys[i];
                        resultObject.display_value = parsedData1.value[0][keys[i]];
                        fields.push(resultObject);
                    result.fields = [];
                    result.fields = fields;
                gs.error('Error ORG');
        } catch (ex) {
            var message = ex.getMessage();
            gs.error("GetCostCenterDetailsError: " + message);
        return result;
    type: 'GetCostCenterDetails'
Try with
    this.token = "" ? this._getToken() : this.token;
and later assign the value to it like
				return token;
and
   try {
			//var token = this._getToken();
            rest1.setRequestHeader('Authorization', 'Bearer ' + this.token);
getACTIVITY2: function() {
        try {
            var r = new sn_ws.RESTMessageV2('CPNYCostCenter', 'Get ACTIVITY');
            r.setStringParameterNoEscape('p_fund', 'AF');
            r.setStringParameterNoEscape('p_org', 'CSIPM');
			r.setRequestHeader('Authorization', 'Bearer ' + this.token);
            var response2 = r.execute();
            var responseBody2 = response2.getBody();
            var httpStatus2 = response2.getStatusCode();
			gs.info("The Activity: " + responseBody2);
             return responseBody2;
        } catch (ex) {
            var message = ex.message;
Also, if you haven’t initialized the script include itself, the this.token wont be initialized as well. So call your function with “mew GettCostCenterDetails().get ACTIVITY2();.
also - good to pass your params to this function adgetACTIVITY2(p_fund, p_org) .
