Restart Workflow for RITM
Dharani2
Need to restart the workflow.
Approval got skipped somehow and workflow is struck. Please let me know how to restart.
Ankur Bawiskar
@Dharani
you can use this script in background for your table record to delete older context and attach new workflow context
(function(){
	try{
		var gr = new GlideRecord('change_request');
		gr.addEncodedQuery('YOUR QUERY HERE'); // PASS your QUERY HERE
		while(gr.next()){
			// cancel old workflows running
			var flows = new Workflow().getRunningFlows(gr);
			while(flows.next()) {
				new Workflow().cancelContext(flows);
			// attach the new context
			var wf1 = new Workflow();
			wf1.startFlow(wf1.getWorkflowFromName('give the workflow name'), gr, 'update');
	catch(ex){
		gs.info('Exception'+ex);
9 REPLIES 9
So it is adding new context but approval is getting skipped
Did you check any user is being set in that user approval activity?
yes the approval triggered to user and user approved it earlier.
The earlier workflow context got cancelled and the new workflow context didn't trigger.
can you share the script you are using as per what I shared?
(function(){
try{
gr.addEncodedQuery('numberSTARTSWITHRITM0029578'); // PASS your QUERY HERE
while(gr.next()){
wf1.startFlow(wf1.getWorkflowFromName('IT-User Support'), gr, 'update');
catch(ex){
so is that not cancelling old and attaching new context?
