Restrict few Knowledge bases to 2 roles
Lucky1
Hello all,
I have a requirement where 2 Knowledge bases (kb_knowledge_base) has to be restricted for both Knowledge manager and Knowledge admin. Apart from those 2 Knowledge bases, they should be able to see all others.
But I have created a group, where those 2 knowledge bases can be seen by the group members.
I have modified the existing oob ACL, but it's not working.
Below is my script:
ACL: kb_knowledge_base -- None
Role: itil
Script:
var kbKnowledge = new KBKnowledgeBase();
// Allow bulk/system updates
if (kbKnowledge.isMultipleKnowledgeUpdate()) {
    answer = true;
// Always allow admin (safety)
// Always allow admins
if (gs.hasRole('admin')) {
    answer = true;
else {
    var restrictedKBs = [
        '9d9f2ab3c3b50e90f07c3be6050131d0',
        '246cdc43dbf1341015c8e16c0b9619ca'
    var allowedGroup = '23a619c7c3f07e508c405883e401312a';
    var kbId = current.kb_knowledge_base + "";
    if (restrictedKBs.indexOf(kbId) > -1) {
        if (gs.getUser().isMemberOf(allowedGroup)) {
            gs.log("KB Article Allowed for group");
            answer = true;
            gs.log("KB Article Restricted");
            answer = false;
        gs.log("KB Article Allowed for all");
        answer = true;
But this is not working because when I impersonate the users and check only last log is coming up. that is, KB Article Allowed for all.
So, can someone help on this please?
Lucky
Hello Atul,
I have opened the Knowledge base and went to Cannot read tab and seen, in the User criteria, the Knowledge_admin and Knowledge manager are also added. So it means that those should not see the Knowledge base right?
But when I impersonate them, still the knowledge base is visible to them.
This is the issue.
Lucky
As per my understanding, you can’t restrict this because these two are major roles that take precedence over everything. These are module-level roles—it’s like owning a house, and you cant enter it anytime.
Hi @Lucky1
I agree with @Dr Atul - LNG on this one. You cant use user criteria to ensure that knowledge manager and knowledge admin can't see the knowledge base... this is contradicting.
AndersBGS
Hi @Lucky1
Why not just utilizing user criteria which is available OOTB.
Hello Anders,
I tried it, but invain.
I opened the Knowledge base and navigated to Cannot read, and in the roles I have updated it with knowledge_manager and knowledge_admin, but still they are able to see.
Might be some inherited roles allowing them ?
Lucky
