Restrict few Knowledge bases to 2 roles
Lucky1
Hello all,
I have a requirement where 2 Knowledge bases (kb_knowledge_base) has to be restricted for both Knowledge manager and Knowledge admin. Apart from those 2 Knowledge bases, they should be able to see all others.
But I have created a group, where those 2 knowledge bases can be seen by the group members.
I have modified the existing oob ACL, but it's not working.
Below is my script:
ACL: kb_knowledge_base -- None
Role: itil
Script:
var kbKnowledge = new KBKnowledgeBase();
// Allow bulk/system updates
if (kbKnowledge.isMultipleKnowledgeUpdate()) {
    answer = true;
// Always allow admin (safety)
// Always allow admins
if (gs.hasRole('admin')) {
    answer = true;
else {
    var restrictedKBs = [
        '9d9f2ab3c3b50e90f07c3be6050131d0',
        '246cdc43dbf1341015c8e16c0b9619ca'
    var allowedGroup = '23a619c7c3f07e508c405883e401312a';
    var kbId = current.kb_knowledge_base + "";
    if (restrictedKBs.indexOf(kbId) > -1) {
        if (gs.getUser().isMemberOf(allowedGroup)) {
            gs.log("KB Article Allowed for group");
            answer = true;
            gs.log("KB Article Restricted");
            answer = false;
        gs.log("KB Article Allowed for all");
        answer = true;
But this is not working because when I impersonate the users and check only last log is coming up. that is, KB Article Allowed for all.
So, can someone help on this please?
Lucky
Tanushree Maiti
Hi Lucky ,
Step1:
  • Navigate to Knowledge > Administration > User Criteria.
  • Create a new User Criteria (e.g Exclude Knowledge Managers/Admins ).
  • In the Advanced tab, use a script to check if the user has one of these roles.
Step2:
  • Navigate to Knowledge > Administration > Knowledge Bases.
  • Open the 2 restricted Knowledge Bases.
  • Navigate to the Can Read related list.
  • Remove any specific roles (knowledge_admin, knowledge_manager as per your requirement) that allow general access.
  • Add the specific group or user criteria created in step 1 that defines who can access it.
