Restrict in RITM level
Chaithu3
Hello Experts,
I have a catalog item, When i submit a request ten it should create a user record in a custom table.
the requirement is not to create a duplicate user in that custom table, So i have written a script that should throw an error message comparing the first name and the last name from table and catalog item.
Now i need help about after approval of RITM then the record insert in the custom table, So different users should not able to create RITM's for same user.
EX : i have submitted a request for a user through the catalog item and it is ready for approval, Then again my colleauge/manager trying to submit a request for the same user. Then it should get restrict saying that an request has been already raised for this user.
Please help ASAP.
Looping @Ankur Bawiskar @Allen Andreas @Dan H @Mark Roethof
Thanks in advance
yes in script include function add this query
So here is your final code
Script Include:
var check_for_users = Class.create();
check_for_users.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	getUserDetails: function() {
		var firstName = this.getParameter('sysparm_old_first_name');
		var lastName = this.getParameter('sysparm_old_last_name');
		var catItemSysId = this.getParameter('sysparm_catItemSysId');
		var che = "";
		var oldUser = new GlideRecord('u_contractors_onboarding');
		oldUser.addQuery('u_first_name', firstName);
		oldUser.addQuery('u_last_name', lastName);
		oldUser.query();
		if (oldUser.hasNext())
			che = "exist";
		var found = this.checkExistingRITM(firstName,lastName,catItemSysId);
		if(che == 'exist' || found == 'exist'){
			return 'exist';
		return '';
	checkExistingRITM: function(firstName,lastName,catItemSysId) {
		var found = 'not exist';
		var ritm = new GlideRecord('sc_req_item');
		ritm.addQuery('cat_item', catItemSysId);
		ritm.addEncodedQuery('stateIN-5,1,2'); // work in progress or open or Pending
		ritm.query();
		while(ritm.next()){
			if(ritm.variables.u_first_name == firstName && ritm.variables.u_last_name == lastName){
				found = 'exist';
				break;
		return found;
	type: 'check_for_users'
onSubmit:
function onSubmit() {
	if (!g_form.ajaxComplete) {
		ajaxCall();
		return false;
	function ajaxCall(){
		var gr = new GlideAjax("check_for_users");
		gr.addParam("sysparm_name", "getUserDetails");
		gr.addParam("sysparm_old_first_name", g_form.getValue('u_first_name'));
		gr.addParam("sysparm_old_last_name", g_form.getValue('u_last_name'));
		gr.addParam("sysparm_catItemSysId", g_form.getUniqueValue());
		gr.getXML(ajaxResponse);
		function ajaxResponse(answers) {
			var answer = answers.responseXML.documentElement.getAttribute("answer");
			if (answer == 'exist') {
				g_form.addErrorMessage('The user is already available in Contractor onboarding table');
				return false;
				g_form.ajaxComplete = true;
				g_form.submit();
Please mark my response as correct and helpful to close the thread
16 REPLIES 16
the solution is already provided in the links I shared.
You need to enhance it as per your script
Hi @Ankur Bawiskar ,
Ill paste the code for you, I have tried still not working. Can you please dont mind modifying it and help me with the 2nd point as well.
Script include :
oldUser.addQuery('u_first_name', this.getParameter('sysparm_old_first_name'));
oldUser.addQuery('u_last_name', this.getParameter('sysparm_old_last_name'));
oldUser.query();
if (oldUser.next())
var che = "exist";
return che;
Client script :
if (answer == 'exist' || answer == exist) {
return false;
return true;
Please help me with the 2nd point as well, It should restrict after submit the request.
2. we should not submit 2 requests on the same user.
Ex : when i submit a request for a user to add in a custom table then he will get added into the table after approval. if i submit a request for a user to that table and without knowledge if any other of my colleauge/manager were trying to add the same user to the table through catalog item, then it throw an error saying "There is alrerady a request raised for this user".
Thanks in advance.
You can try from your side; the logic is already shared in the links.
you just need to enhance it
OR
create 2 onChange client scripts 1 each on first name and last name
validate the data
if validation fails; then clear the variable and make it mandatory
Thanks @Ankur Bawiskar ,
The first point got completed, I was talking about the second point which is the major part of the question.
combine validation for both the points in same script include
Script Include for that
		var che = "";
		oldUser.query();
			che = "exist";
			return 'exist';
		return '';
		ritm.query();
		while(ritm.next()){
				found = 'exist';
				break;
		return found;
onSubmit:
			return false;
			return true;
I  hope this will help you to mark my response as correct and helpful to close the thread.
