03-20-2022 11:33 PM
Hello Experts,
I have a catalog item, When i submit a request ten it should create a user record in a custom table.
the requirement is not to create a duplicate user in that custom table, So i have written a script that should throw an error message comparing the first name and the last name from table and catalog item.
Now i need help about after approval of RITM then the record insert in the custom table, So different users should not able to create RITM's for same user.
EX : i have submitted a request for a user through the catalog item and it is ready for approval, Then again my colleauge/manager trying to submit a request for the same user. Then it should get restrict saying that an request has been already raised for this user.
Please help ASAP.
Looping
Thanks in advance
03-22-2022 09:08 AM
yes in script include function add this query
So here is your final code
Script Include:
var check_for_users = Class.create();
check_for_users.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getUserDetails: function() {
var firstName = this.getParameter('sysparm_old_first_name');
var lastName = this.getParameter('sysparm_old_last_name');
var catItemSysId = this.getParameter('sysparm_catItemSysId');
var che = "";
var oldUser = new GlideRecord('u_contractors_onboarding');
oldUser.addQuery('u_first_name', firstName);
oldUser.addQuery('u_last_name', lastName);
oldUser.query();
if (oldUser.hasNext())
che = "exist";
var found = this.checkExistingRITM(firstName,lastName,catItemSysId);
if(che == 'exist' || found == 'exist'){
return 'exist';
return '';
checkExistingRITM: function(firstName,lastName,catItemSysId) {
var found = 'not exist';
var ritm = new GlideRecord('sc_req_item');
ritm.addQuery('cat_item', catItemSysId);
ritm.addEncodedQuery('stateIN-5,1,2'); // work in progress or open or Pending
ritm.query();
while(ritm.next()){
if(ritm.variables.u_first_name == firstName && ritm.variables.u_last_name == lastName){
found = 'exist';
break;
return found;
type: 'check_for_users'
onSubmit:
function onSubmit() {
if (!g_form.ajaxComplete) {
ajaxCall();
return false;
function ajaxCall(){
var gr = new GlideAjax("check_for_users");
gr.addParam("sysparm_name", "getUserDetails");
gr.addParam("sysparm_old_first_name", g_form.getValue('u_first_name'));
gr.addParam("sysparm_old_last_name", g_form.getValue('u_last_name'));
gr.addParam("sysparm_catItemSysId", g_form.getUniqueValue());
gr.getXML(ajaxResponse);
function ajaxResponse(answers) {
var answer = answers.responseXML.documentElement.getAttribute("answer");
if (answer == 'exist') {
g_form.addErrorMessage('The user is already available in Contractor onboarding table');
return false;
g_form.ajaxComplete = true;
g_form.submit();
Please mark my response as correct and helpful to close the thread
03-27-2022 08:15 PM
I believe I have provided enough support, help and guidance for your question.
I could see you marked my response as helpful.
Please mark my response as correct and close the thread.
03-30-2022 04:08 AM
