Restrict Unique rows in MRVS
pramodkumar
We have a MRVS on a catalog form. One variable in mrvs is "type" (select box) which has values A, B, C, D. we need to restrict one entry for type selected. User should  enter only one row for A, B, C, D. How can we achieve this?
Thanks!
Ankur Bawiskar
@pramodkumar
check this checkbox under that variable within that MRVS
OR script based solution
check this link for solution
How to stop duplicates entering in MRVS based on MRVS Variables(Applies Catalog item/ServicePortal)
@pramodkumar
you will have to write onSubmit catalog client script which applies to Catalog Item
Get the MRVS value, parse that json and check
this link has solution shared by me, enhance as per your requirement.
Validation on Multi Row variable set (same role cannot be allowed).
Ankur Bawiskar
@pramodkumar
Request you to close your earlier questions by marking appropriate response as correct.
I have provided solutions for few of those.
Members have invested their time and efforts in helping.
