Right Click Menu missing
humblecommitted
Hello community,
I need help in trying to figure out how to restore the right click features I had for my Change request page.   Please help!
When I right click on the Change Request gui, it use to give me this menu:
Now it gives me the standard web browser right click menu:
This error occurred after I tried to delete a "many-to-many" change request file.   it was entitled m2m_chang_request_chang_request.
Any help would greatly be appreciated.
humblecommitted
I was able to find the solution to this problem by going into the deleted application files and restoring them:
Then I went into Restore application files:
I then went into each one and restored the sys_ui_list back to before any changes occurred before the right click problem.
11 REPLIES 11
Not sure if this has anything to do with what you are alluding to but when I check any onload client script for CRs, I get this message
Hello Gurpreet,
Would you mind supplying additional information and screen shots on what ui polices would control a right click short cut menu on the Change request table?
Vikas-Malhotra
Mega Guru
Check if you have the relevant roles to do so and if you have the relevant role and you still can't see the context menu for any form then you can check for this macro "context_form_header".. if this is active true or not.
Hope its helpful.
Thanks and Regards,
Vikas Malhotra
Hello Vikas,
I was able to navigate to "context_form_header" via System UI> UI Macros
it looks activated to me:
are there any other tricks I can try?
Thank you
Just search in the UI Macros like this:
Hope it's helpful.
Thanks and Regards,
Vikas Malhotra
