RITM Fix Script Help!
Snow Angel
Hello all,
I need to update multiple historical RITM records where field name is start_date (a variable on RITM)  on sc_req_item, the value of the field should be updated to 2020-10-21.  Please can someone help me to fix the below script.
*I have tried th ebelow but its not updating the variable which is btw greyed out/read only.
// Define the list of RITM numbers
var ritmNumbers = 'RITM0095731';
// Update the start_date field for the specified RITM numbers
gr.addQuery('number', 'IN', RITM0095731);
while (gr.next()) {
    gr.start_date = '2020-10-21';
    gr.update();
gs.info('start_date field updated for the specified RITMs.');
James Chun
Hi @Snow Angel,
Since it's a variable, you need to use the variables object.
Replace the following
with
 gr.variables.start_date = '2020-10-21';
Also make sure you have the speech marks around the number when you are querying by a number.
i.e.
gr.addQuery('number''IN', 'RITM0095731');
Cheers
James Chun
Hi @Snow Angel,
with
i.e.
Cheers
