RITM Variable Not Saved in Native View but Saved in Workspace (sc_item_option Not Updated)
Baskarank
When editing an existing Requested Item (RITM) in the Native UI, catalog variables (example: Choose  option : A, B,C) do not persist after saving.
However, when the same RITM is edited and saved from Service Operations Workspace (SOW), the variable value is correctly saved and the record is created/updated in the sc_item_option table.
Observed Behavior
  • User selects a carrier value on RITM form in Native UI
  • Clicks Save
  • Variable appears empty after refresh
  • No value is written to sc_item_option
But:
  • Opening the same RITM in SOW
  • Selecting carrier and saving
  • Value is successfully stored in sc_item_option
🔹 Expected Behavior
Catalog variables should be saved consistently from both Native UI and Workspace UI when updating an RITM.
🔹 Verification Done
  • Variable definition checked and is active
  • sc_item_option table confirms value only saves via Workspace
  • Issue reproducible consistently
@Ankur Bawiskar It's happen both admin and non admin users.
this issue happening earlier (3months before)
yes recently upgrade
@Baskarank
if it's happening for all RITM then looks like a platform issue.
Please raise a case with ServiceNow and keep us posted.
