Roles docs required
Yasin Shaik11
Need help for the below.!
I need list of OOB roles for the incident and problem and change and knowledge managements. Does anyone share me reference links or docs
Thanks in advance 🙂
Hi @Yasin Shaik11 ,
On your PDI it's Free, you don't pay anything. those roles comes with the base system, pre-installed.
Hi @Yasin Shaik11 ,
Yousaf
Hi Yasin,
I believe you are looking for this ? not sure
Base system roles
Mark Correct and Helpful if it helps.
***Mark Correct or Helpful if it helps.***
