Sample Project Plans
MGanon
Does anyone have sample implementation project plans?
Noah Drew
Hello @MGanon !
If you have an Instance with Demo Data installed for Project Portfolio Suite with Financials Plugin, you can go to the Project Templates table for a good Implementation Plan.
To get there:
1. Navigate to Project Administration > Settings > Templates - Project
2. Look for the record with the Name of "ServiceNow Implementation Template" and go to the record
3. Notice the Project Template Tasks such as "Initiating" , "Planning", "Project Kick-off Meeting", "Gain Formal Acceptance" etc.
Hope that helps!
If it did, please mark as Helpful and consider setting the reply as the Correct Answer to the question, thanks!
salkhodhair
Does anyone has ServiceNow implementation project plan in MS Project version?
