save as draft functionality not working as expected in catalog item
sln
When a catalog request is saved as draft, on the draft record few conditionally dependent variables are hidden even when they are made visible on normal request form and few variable values are cleared. Please let me know if this can be solved without disturbing existing scripts.
14 REPLIES 14
Hi @tejaswinisa
No mate, no solution for this 😞
Hi @Dr Atul - LNG , do you have any idea on how to achieve this by modifying the existing client scripts. Thanks.
Hi @sln
No mate, the only solution I can think of is applying a client script on the field to display a message warning the user to avoid saving in draft. Otherwise, they’ll have to fill in the variable values again. It’s just a workaround.
Ankur Bawiskar
@sln
when the saved version is opened you can ensure your catalog UI policy or catalog client scripts doesn't run in that mode
It runs only in normal mode
In your onLoad client script you can check the browser URL contains edit=draft
if yes then don't run your client script -> this ensures your variables are intact
@sln
Hope you are doing good.
