script for Kill schedule jobs running more than 30 mins
Dhanu1
Can anyone help me to write script for kill the scheduled jobs running more than 30 mins.
we have option to manually kill but we need to automate by checking the age > 30 mins
Thanks in advance
Mohan raj
Hi @Dhanu1,
Try this code
var trigger = new GlideRecord('sys_trigger');
trigger.addQuery('state',1)//state is running
trigger.addQuery('processing_duration','<','1800000')//scheduled jobs running more than 30 mins
trigger.query();
while(trigger.next()){
    GlideTransactionManager.kill(current.session_id);
​If my response helps you to resolve the issue close the question by Accepting solution and hit thumb icon. From Correct answers others will get benefited in future.
Mohan
Mohan raj
Hi @Dhanu1,
Try this code
trigger.query();
Mohan
Pratima G
where can we use this script ? can we use it directly into the scheduled job to check if it is running for more that 30 minutes ?
karthick8
GlideTransactionManager.kill(session_id);  is not working in script background
