How to check which script/flow adds an Additional Comment to a RITM?
There is a particular comment that is added from an unknown source in my RITMs when I use a particular UI Action. I can't find it in any configurations, so I wonder if there still is a way to use something like the good old Field Watcher in order to find and modify that script that I cannot find.
@Community Alums
try to use script tracer and debug
Script Tracer and debugging scripts
Mastering the Script Tracer in ServiceNow: A Guide to Debugging Server-Side Scripts
Ankur Bawiskar
@Community Alums
places to check
1) script include
2) business rule
3) script actions
4) flow
5) subflow
6) workflow
7) scheduled job
comments get added with system user or which user?
it's added by the user who clicked the UI Action. Also checking all of that would be a nightmare and take hours: there are HUNDREDS of script to look through. I'm asking if there's a shortcut.
@Community Alums
Found it, thanks!! It was one of the BRs that was found in the Tracer.
