Script include is not working properly
satya30
Script include is successfully receiving the values of sys id from client script but objects are not returning.  Please help me on how to return correct values from script include. Thank you
Script include:
gs.info("check if it is checking for property: " +prop, +answer); - till here it is working properly
getPropertyData: function(sysId) {
        var answer = {};
        var prop = sysId || this.getParameter("sys_id");
		gs.info("Script Include 'sn_customerservice.CHCSMUtilsv2' was called with property '" + prop + "'");
        var pr = new GlideRecord("customer_account");
        //pr.get(prop);
		pr.addQuery('sys_id', prop);
		pr.query();
		if(pr.next())
		answer.property_code = pr.number.toString();
        answer.secondary_id = pr.u_secondary_id.getDisplayValue();
        answer.name = pr.name.getDisplayValue();
        answer.brand_code = pr.u_brand;
        answer.brand_name = pr.u_brand.getDisplayValue();
        answer.product_code = pr.u_brand_sub_class;
        answer.product_name = pr.u_brand_sub_class.getDisplayValue();
        answer.street = pr.street.toString();
        answer.city = pr.city.getDisplayValue();
        answer.state = pr.state.toString();
        answer.postal_code = pr.zip.getDisplayValue();
        answer.country_code = pr.country.getDisplayValue();
        answer.country_name = pr.u_country_name.getDisplayValue();
        answer.email = pr.u_email.getDisplayValue();
        answer.phone = pr.phone.getDisplayValue();
        answer.general_manager = pr.u_general_manager.toString();
        answer.area_director = pr.u_area_director.toString();
        answer.ar_dir = pr.u_area_director.getDisplayValue();
        answer.rvp = pr.u_area_director.manager.toString();
        answer.rvp1 = pr.u_area_director.manager.getDisplayValue();
        answer.reservation_status_code = pr.u_reservation_status;
        answer.reservation_status = pr.u_reservation_status.getDisplayValue();
        answer.call_fwd = pr.u_call_forwarding_program.toString();
        answer.call_fwd_mobile = pr.u_call_forwarding_mobile_program.toString();
        answer.call_fwd_plus = pr.u_call_forwarding_plus_program.toString();
		answer.contract_status_code = pr.u_effective_contract_status.getValue();
		answer.u_guest_room_count = pr.u_guest_room_count.getValue();
		gs.info("Loop is working correctly: "  +answer);
		gs.info("Script Include 'sn_customerservice.CHCSMUtilsv2' was called with property '" + prop + "', brand: " + answer.brand_name);
        var result = JSON.stringify(answer);
        //Debugger:
        gs.info("Script Include 'sn_customerservice.CHCSMUtilsv2', function 'getPropertyData': Found " + pr.getRowCount() + " record using parameter '" + prop + "':: '" + result + "'");
        return result;
Client Script: Here we need all those additional object values as it is being used in Many other items.
    if (newValue == '') {
    var ga = new GlideAjax("sn_customerservice.CHCSMUtilsv2");
    ga.addParam("sysparm_name", "getPropertyData");
    ga.addParam("sys_id", newValue);
    ga.getXMLAnswer(setPropData);
    function setPropData(response) {
    if (response) {
        //  var answer = response.responseXML.documentElement.getAttribute("answer");
        var answer = JSON.parse(answer);
        g_form.setValue("property_info_name", answer.name);
        g_form.setValue("property_info_state", answer.state);
        g_form.setValue("property_info_country", answer.country_name);
        g_form.setValue("property_info_phone", answer.phone);
        g_form.setValue("property_info_email", answer.email);
        g_form.setValue("property_info_area_director", answer.area_director);
        g_form.setValue("property_info_rvp", answer.rvp);
        if (g_form.getValue("internal_user") != "true") {
            g_form.setValue("contact_info_phone", answer.phone);
            g_form.setValue("contact_info_email", answer.email);
Hi @satya30,
I try to test the script include by passing the sysId in Background script, get the log which mentioned. It working for me in Background script.
Robert H
If the "Loop is working correctly" line is not printed to the log then there's an issue somewhere in the lines of code that populate your "answer" object. Try wrapping those lines into a try ... catch block and check if an error is printed.
try {
	// add all your other code that populates the "answer" object here
} catch (error) {
	gs.error(error);
gs.info("Loop is working correctly: "  +JSON.stringify(answer));
Robert
Nishant8
Tera Sage
Hello @satya30, can you please try to call your SI using Background script and verify whether you see log statements are printed? If its working fine  there, then enable the Standbox checkbox there on the Script Include if you are in Xanadu or higher.
Refer:
https://www.servicenow.com/docs/bundle/yokohama-platform-security/page/administer/security/reference...
Nishant
