Script include not working for onchange catalog client script
chandan15
We have a catalog item where we have 3 variable, first variable 'Find' getValue(find) and will search all the "KB_KNOWLEDGE" body, and fetch all kb number, and the second one will replace all the KB body with new texts.
I have write below script include and client script which fetching the empty data.
Script Include:
var findKB = Class.create();
findKB.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getGEMSKB: function() {
        var fvar = current.variables.find;
        var gr = new GlideRecord('kb_knowledge');
        gr.addQuery('text', 'CONTAINS', fvar);
        var kbnum = ''; // Declare kbnum outside the if block
        if (gr.next()) {
            kbnum = gr.number; // Assign the value inside the if block
        return kbnum;
    type: 'findKB'
Client script-
    var fvar = g_form.getValue('find');
    var ga = new GlideAjax('findKB');
    ga.addParam('sysparm_name', 'getGEMSKB');
    ga.getXML(getValue);
function getValue(response, fvar) {
    console.log('Response String: ' + answer);
	g_form.addInfoMessage(answer);
    g_form.setValue('kb_articles_with_find_term', answer);
Passing empty addInfoMsg-
Rahul Talreja
Hi @chandan15 ,
Try with :
        var fvar = this.getParameter('sysparm_fvariable');
        if (gr.next()) {
        return kbnum;
    type: 'findKB'
    //var fvar = g_form.getValue('find');
   // Hope you wanted to pass the new value of the on change field every time.Use below line
   var fvar = newValue;
    ga.addParam('sysparm_fvariable',fvar);
    ga.getXML(response);
function response(res) {
    var answer = res.responseXML.documentElement.getAttribute("answer");
Please mark my response correct/helpful as applicable!
Thanks and Regards,
Rahul
Rahul Talreja
Hi @chandan15 ,
Try with :
        if (gr.next()) {
        return kbnum;
    type: 'findKB'
Thanks and Regards,
Rahul
Awesome, it started working, Since a long time I am working in multiple script, but still I am need help for debug. Thank you very much.
Nayan  Dhamane
Hello @chandan15 ,
The main issue in the script is you have not passed the find value parameter from client script to script inlcude and then call the same in the script inlcude.
Please use the below script snippets:
        var fvar = this.getParameter('sysparm_var');
        if (gr.next()) {
        return kbnum;
    type: 'findKB'
    ga.addParam('sysparm_var',fvar);
If my answer solved your issue, please mark my answer as Correct & Helpful based on the Impact
Best Regards,
Nayan Dhamane
ServiceNow Community Rising Star 2023.
Harish KM
Hello in your script include replace the below line
to
var fvar = this.getParameter('sysparm_var'); //this one needs to be passed from your client script which you have
Harish
