Search on Two Columns with Reference Field Variable
Shivam Saxena1
Mega Expert
There is a reference field named as 'Asset' in my change form.
When we click on search icon we have below columns.
Right now we can able to search based on column 'Name'.
I want a user can able to search the asset directly by typing in refence field using column 'Name' - name and 'Asset Tag' - asset_tag. When he give name then also it will show the result and if the user give asset tag then also he can able to search.
Right now I am getting below error when I am trying to search using asset tag.
Below is the field dictionary :
What script I need to write and where? Please help?
Thanks.
then using this it should work
ref_auto_completer=AJAXTableCompleter,ref_ac_columns=name;asset_tag,ref_ac_columns_search=true
Are you checking with admin or non-admins
25 REPLIES 25
If the table name is cmdb_ci_hardware (which is not asset table), then try like this.
And most importantly when you are searching chck the ref qual conditions and check if you are getting that name there or not.
change the reference to chasis table and check it once.
Hi Asif,
It is working for asset. No worries. Thanks for your help.
Thanks.
Hi Shivam
I noticed that you have marked my comment as correct answer but now it is not.
if you are using asset table, then the column name is display_name which i have correctly mentioned earlier to you. The comment that you have marked as correct is saying name which is not the case.
Please check and mark appropriate comment as  a correct answer so that others who are looking for similar solution can be benefitted.
yes. corrected. thanks.
