Send a Notification Based on field updating
varma2
Need to trigger a notification in a Pm_project table. we have filed called Percentage complete  in Pm_project  table and we have form section which is Status report under this they will create record in project_status table,
My trigger condition IS. if below condition met notification should trigger.
Status Report not submitted in the last 7 days
Percent Complete not updated in the last 7 days
Please suggest,
Thank you all.
2 ACCEPTED SOLUTIONS
Ankur Bawiskar
@varma2
is that table "pm_project" audited?
If yes then you can use advanced notification condition and use script, I assume your notification is on pm_project table
1) query sys_audit table and see when was the last update to Percent complete
2) in the same advanced notification condition script, query status report table for this Project and see if any record was created or not in last 7 days
based on that set answer=true to send email
something like this but please enhance
 var projectId = current.sys_id;
 var sevenDaysAgo = new GlideDateTime();
 sevenDaysAgo.addDaysUTC(-7); // Get the date 7 days ago
 // Check if "Percent Complete" was updated in the last 7 days
 var percentCompleteUpdated = false;
 var auditGR = new GlideRecord('sys_audit');
 auditGR.addQuery('tablename', 'pm_project'); // Table name
 auditGR.addQuery('fieldname', 'percent_complete'); // Field name
 auditGR.addQuery('documentkey', projectId); // Project sys_id
 auditGR.addQuery('sys_created_on', '>=', sevenDaysAgo); // Changes within last 7 days
 auditGR.query();
 if (auditGR.hasNext()) {
     percentCompleteUpdated = true; // Found an update for "Percent Complete"
 // Check if a status report was submitted in the last 7 days
 var statusReportSubmitted = false;
 var statusReportGR = new GlideRecord('project_status');
 statusReportGR.addQuery('project', projectId); // Filter by current project
 statusReportGR.addQuery('sys_created_on', '>=', sevenDaysAgo); // Submitted within last 7 days
 statusReportGR.query();
 if (statusReportGR.hasNext()) {
     statusReportSubmitted = true; // Found a status report submission
 // Trigger notification if both conditions are not met
 if (!percentCompleteUpdated && !statusReportSubmitted) {
     answer = true;
     answer = false;
Thanku @Ankur Bawiskar ,
Can we send weekly once the notification using schedule job with below script.
 auditGR.query();
     answer = true;
     answer = false;
Please suggest.
Thank you
Shivalika
Hello @varma2
This is a related list "Status report" and not a form section.
What's the relationship between this status report and project table ? Based on this relationship you can easily check if there are records.
Then use gs.eventQueue() to trigger event and in the notification.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this questions from unsolved to solved bucket.
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeEISQCY
