Servicenow & Test Case Management - is it possible?
longs1
Hi, does anybody know if ServiceNow can be used for test case managment?   Currently we are using JIRA to manage projects but I have been informed we may be replacing it with ServiceNow.   I would like to import test cases into servicenow and ask users to execute their tests from their, like the JIRA functionality
Then the only option left is to creating a new tale called 'Test Cases'
Agreed, as I say I don't believe SNOW does this out of box, but it should be easy to develop.
solutioningnow
Giga Guru
Since the test cases are part of SDLC application in OOB. If you have different requirement and you dont want to use SDLC application. Than I would suggest create custom table called "Test Cases" by extending Task.
Let me know if you have any queries
Solutioner
juola
Hi Simon,
Just found out today that Oliver Schmitt has created a custom app for "UAT Testing" and it's available in ServiceNow Share. So, thank you Oliver!
This seems to work well for planning and performing tests. Maybe someday this will be an official plugin in ServiceNow.
atfa
Kilo Explorer
There is this new one also available in share:   https://share.servicenow.com/app.do#/detailV2/b5d9893a2bb0b100bddaff70f8da155e/overview
I hope this helps
