Servicenow Integration with Clarity for Project Portfolio Module Urgent guidance required.
taylor13
Has any one done integration with Service now and Clarity?
@Ankur Bawiskar @Community Alums
Vishal36
Mega Guru
Hi @taylor13
OpsHub, a ServiceNow partner with a certified integration tool, offers an integration platform that can help ease your integration journey by facilitating a bidirectional integration between ServiceNow and Clarity systems.
OpsHub takes care of the following use cases, also:
  • Integration Richness: OpsHub can integrate the complete work item information such as attachments, web links, comments, traceability, and inline images on ServiceNow and Clarity, without requiring any scripting.
  • Field-level Conflict Management:  As this is a bidirectional integration, there is a possibility of data being updated simultaneously in both instances. OpsHub supports field-level conflict management in such cases.
  • Supported entities: All System and Custom Tables on ServiceNow and Project, Task, To do on Clarity are supported by the OpsHub integration tool.
You can also reach out to OpsHub’s integration experts for an initial discussion on your use case and planning of integration strategy.
Vishal
