ServiceNow to ServiceNow Integration
09-05-2023 05:32 AM
what do I put for PUT Url ,I'm trying to do update integration or can anyone can guide me for complete update integration.
09-07-2023 06:15 AM
Test using user with Admin role once, hope it PDI so you can test it if it works then it could some ACL. Let me know if you still have issue even using Admin user.
sn_incident_write role should be sufficient we can troubleshoot the access part. Also share the screenshot of the HTTP Method.
Mark this as Helpful and Accept the Solution if my response helps to solve your issue.
09-05-2023 07:01 AM - edited 09-05-2023 07:01 AM
Hi @sabasiddiqui777 Can you please try updating the end point URL as below
https://dev137561.service-now.com/api/now/table/incident
Thanks & Regards,
Eswar Chappa
Mark my answer correct and Helpful if this helps you 😀
09-06-2023 12:35 AM
