Set Assignment group at RITM level from catalog task script in workflow
Apex Predator
Kilo Expert
I have a catalog item and a workflow. In my workflow, I have a catalog task with a script like thisfind_real_file.png
Can I set the Assignment Group at the RITM level from here. My task get an assignment group set using assignment rules. I want the same group to appear here. How can do it using this script?
Thank you
I don't want to assign the group to the task. I want it the other way around. I was able to achieve this in the workflow by modifying the above mentioned script and putting it inside the 'Run Script' in workflow. I query the task table with the sys_id of RITM, get the task object, get it's assignment group and assign it to RITM's assignment group.
