Set RITM to Work in Progress
Rocky5
Hello Experts,
I wanted to set RITM state to "Work in Progress" when any catalog task state of that RITM is set to "Work in progress", I have written the below script "after" update BR on Sc_Task table, It works as expected but some Random blank RITMs are getting created. Assuming that is because sc_task doesn't have request_item as soon as gr.update(); happens on the empty gliderecord it is inserting the new record.
Is my assumption correct? if so, what is other alternative to achive this requirement.
After update BR on sc_task table:
    gr.get(current.getValue('request_item'));
    gr.state = 2;
    gr.update();
})(current, previous);
Rocky.
I tried but no luck.
Rocky.
What is the "When to Run" conditions you are using?
