Set values on a record using business rule
11-02-2022 06:16 AM
I have created a business rule to set values on the "assessment instance question" table. I am not able to set the values. I can see the values in the logs. But still i am not able to set those values.
Below is my business rule.
var arrQust = [];
var obj = {};
var recordSysId = current.getValue('sys_id');
var wfd = new GlideRecord("u_wfd_assessment"); // custom table
wfd.addQuery('u_assessment_number', recordSysId);
wfd.query();
if (wfd.next()) {
var wfdQust = new GlideRecord('asmt_assessment_instance_question');
wfdQust.addQuery('instance', recordSysId);
wfdQust.query();
while (wfdQust.next()) {
obj = {
metric: wfdQust.getDisplayValue('metric'),
value: wfdQust.getValue('value'),
stringValue: wfdQust.getValue('string_value')
arrQust.push(obj);
gs.info("WFD : Business Rule: arrQust: " + arrQust);
gs.info("WFD : Business Rule: JSON.stringify(arrQust): " + JSON.stringify(arrQust));
for (var i = 0; i < arrQust.length; i++) {
gs.info("WFD : Business Rule: Assessment Number: " +wfd.getValue("u_assessment_number") + ",arrQust[i].metric: " + arrQust[i].metric + " ,arrQust[i].value: " + arrQust[i].value + " ,arrQust[i].stringValue: " + arrQust[i].stringValue);
if (arrQust[i].metric == "Product") {
gs.info("WFD : Business Rule: Inside if block " + arrQust[i].metric);
wfd.product = arrQust[i].stringValue;
//wfd.update();
} else if (arrQust[i].metric == "ID") {
wfd.u_id = arrQust[i].stringValue;
//wfd.update();
} else if (arrQust[i].metric == "Application Type") {
wfd.u_application_type = arrQust[i].stringValue;
//wfd.update();
} else if (arrQust[i].metric == "Application") {
wfd.u_application = arrQust[i].stringValue;
//wfd.update();
wfd.update();
})(current, previous);
11-03-2022 03:14 AM
@Hari1 were you able to achieve this?
11-02-2022 06:36 AM
Hi @Hari1 ,
on this table u_wfd_assessment you are setting and updating the values.
if you want to update values in asmt_assessment_instance_question table. you need to use like below.
Example:
wfdQust.product = arrQust[i].stringValue;
wfdQust.update();
My understanding: But from you are script getting values from the asmt_assessment_instance_question table and based on certain conditions you are updating u_wfd_assessment this table.
11-02-2022 07:01 AM
Hi @Hari1 ,
Try this script
var arrQust = [];
var obj = {};
wfdQust.addQuery('instance', current.getValue('sys_id')); //current record sysid should match with instance sysid
wfdQust.query();
obj = {
arrQust.push(obj);
var arrQustJSON = JSON.parse(arrQust);
for (var i = 0; i < arrQustJSON.length; i++) {
if (arrQustJSON[i].metric == "Product") {
current.product = arrQustJSON[i].stringValue;
} else if (arrQustJSON[i].metric == "ID") {
current.u_id = arrQustJSON[i].stringValue;
} else if (arrQustJSON[i].metric == "Application Type") {
current.u_application_type = arrQustJSON[i].stringValue;
} else if (arrQustJSON[i].metric == "Application") {
current.u_application = arrQustJSON[i].stringValue;
current.update();
11-11-2022 03:50 AM
Hi @Hari1 ,
If your issue got resolved close the question by Accepting solution and hit thumb icon.
If not reply and share details.
11-13-2022 11:29 PM
Hi @Hari1 ,
If still not resolved reply and share details will try to resolve your issue.
