Setting a default value in a variable
johndarroch
I am very new to scripting and need some help on the following
I am creating a Catalog item which has a variable name called Application which is a reference field to the Application table . I want the field owned by for that application on the application table to populate the variable Owned By on the catalog item.
Its probably easy for all you awesome developers so any help would be very much appreciated .
Thanks JD
Hi John,
You variable owner should be a reference variable pointing to the user record.
You rock thank you !!
Happy Holidays
Hey John,
You might have to change your 'Owner' variable to a reference type, pointing to sys_user table.
amlesh
Hi John,
If my response resolved your issue, would you Please mark the answer as correct.
Do I click Helpful = Yes
Also another quick question if I wanted to set another variable would I just add it to the end or create another script ?
