Setting a default value in a variable
Options
‎12-21-2017 01:31 PM
I am very new to scripting and need some help on the following
I am creating a Catalog item which has a variable name called Application which is a reference field to the Application table . I want the field owned by for that application on the application table to populate the variable Owned By on the catalog item.
Its probably easy for all you awesome developers so any help would be very much appreciated .
Thanks JD
Options
‎12-22-2017 11:02 AM
Thank you. and Yes, Just add it to end, if its a reference of your application table.
