Setting a max stock threshold and sending notifications
sidsonrexa
Hello. New to ServiceNow and so far I really like the tool. Quick question regarding stock rules within inventory management.
ServiceNow lets you create stock rules to manage items that fall below a certain threshold by automatically either sending a notification or create transfer orders to replenish the stock. Our company leases a large portion of their assets and so don't have a large on-site stockrooms, instead we keep a small number on hand and bigger inventory is maintained at a vendor managed warehouse.
In addition to the existing stock threshold functionality the users would like the ability to specify a 'max threshold' as well. If the number of items in a stockroom reaches or exceeds the max threshold the stockroom manger should get a task to ship the excess inventory to the vendor warehouse. Is this already handled by ServiceNow? If not what would be the best way to provide this functionality?
brianquinn
Siddharth,
If all you need is a simple email notification, you can create a new Notification by going to "System Policy -> Notification" and then clicking on the "New" button.
If you want the notification to go out when the stock level goes above 10 for instance, you could configure the following:
Table: Consumable [alm_consumable]
When to send: On Inserted, On Updated
Conditions: "Quantity" "greater than" "10"
If you had a different maximum for different types of items, you could add a notification for each type of item and add a condition to filter based on Model, or display name or something similar.   Another option would be to add a new field "Maximum Quantity" field to the alm_consumable table, and use the notifications "Advanced condition" to use javascript to compare the quantity field to the new maximum quantity field.
Brian
Surendar_M
Hi @sidsonrexa ,
We have a similar requirement to introduce max threshold for the stockroom and would like to know the approach that helped in implementing the solution.
