Show reports in power bi for problem list
chandan1994
Hello Team,
i have a requirement to show the report in power bi from servicenow problem table, please how to do this.
should i do power bi integration , if yes please provide the steps too as i am new to integration.
Thanks in advance.
Raks
I guess there some issue with the URL you are using:
Go to REST APi explorer and in there below the Prepare request option select the problem table from the drop down.
Click on the send button you will get a correct url for the request .
replace the url in code with the one you will get in the REST API explorer.
Remeber to change this part only.
https://<host>.com/api/now/table/problem
27 REPLIES 27
Hello Aldrin,
you are not doing any changes in servicenow ?
only you have created a user in servicenow and this api you are passing in power Bi ?
yes i am not changing anything in servicenow. our servicenow support team created us a service account then they provide read access to REST API
Can you please share the exact error that is received.?
The error is "We couldn't authenticate with the credentials provided. Please try again"
That is always the error I get even I entered the username and password accurately.
Rajat15
Hi ,
How does it work with Scripted REST APIs instead of REST API explorer.
